id liek to get this back up there and get some opinions on my current setup and where i should gead to next.
Currently i have a 1gb Eclipse, it was a 7bolt NT/Auto,
First step was to put a rebuilt 91 6bolt motor in it
Current Mods:
-Turbo intake cam
-5spd turbo injectors - 450cc's, with the resister pack
-Stock turbo fuel pump (190? lph)
-Cold air intake, hacked mas, K&N filter. cut the sheetmetal up behind the headlight to flow into the intake better
-Cheap OBX header that is port matched to the head
-Pacesetter cat-back, 2.5" mandrel bent, removed the stock pacesetter muffler, cheap flow-throw
-Cheap adjustable FPR
-1990 Turbo 5spd trans, ACT2100, Fidanza aluminum flywheel, steel braided clutch line, all shit kits, extended slave rod
Im still having issues with it running rich, it seems like, although i havnt installed a air fuel meter or fuel pressure gauge.
I was thinking about maybe installing a small spray kit and running nitrous at the track just for that extra oomph. this car doesnt see much drag racing, mostly autox, and running the twisties
What else would anyone recomend? anyone know what else i should do to try and tune it a bit?
Nick
aim - slowtxdsm
____________________________
93 Eclipse Shell
6bolt/5spd swapped
