Apexi AFC NEO
Dasamary
85
Feb 27, 2006
West Chester, Ohio
Not sure if anyone on the NEWBIES section has the new NEO but I had a quick question. Is the Air/Fuel Ratio monitoring that the NEO does a Wideband? Or do I need a seperate wide band to monitor true Air/Fuel ratio.
Thanks!
Yeah I don't have personal experience, but from what I read it is like the first one's where you get a voltage reading that would be loosely translated into a A/F reading.
The afc dont show anything about air fuel ratios most def. need a wideband plus where would a afc tap in to read AFRs
You can go off of the stock o2 sensor if you want a rough reading. When tuning, around .93-.94V is a good place to tune. It just doesn't use a 5V reference like the AEM.
