1G 1ga headlight wires
Kainnen
38
May 8, 2005
dartmouth,
Im trying to hook up some new popup lights on my 91 laser but i cant find the wire information. I need to hook up a new adapter which has 3 wires and the stock wires have 3 but they are all red. One looks solid red and one is red with a yellow stripe and one looks to have a blue stripe. Anyone know what wire does what?
if nobody answers this by the time i go downstairs and check my mail, ill go look on my car. i did a 1ga front end conversion so mine might have the same colors.
ok i looked on mine and the ground was a red cable with a white stripe. as far as the other two, one is the normal light and the other is the highbeam. im not sure if that's going to help you any. in your case, i would go with the red & blue one as the ground. your solid red should be the normal light. hope that can help you some.
