Step 2: Fuel pump
There are many parts that can be installed before you actually go turbo. The Fuel system is one main thing. I installed the Fuel pump and FMU weeks before i saw any boost and everything ran perfectly fine. I also installed my gauges before too(call me a ricer if you must, but i had a boost gauge before boost :P)
The fuel pump is pretty strait forward install. first thing you need to do is remove the back seat. On the passanger side, there will be a little cover being held on by 4 screws. remove these screws and pull the cover off and push it to the side. you can try to unhook the wiring harness and remove the cover completely but i couldnt get it off. next remove the fuel lines attached to the pump cover. Have some towels incase you get some excess fuel spilling out. The hard line is not braized as some have said(atleast the fuel pump side isnt) and i just popped it loose with a wrench. remove the hard line and return line. there are 6 bolts that are 5/16(not metric for some reason) that hold the pump cover on. remove these, and the pump should pull right out. now, on the pump there is a screw on the brass bracket, remove this, and unplug the harness and unhook the hose(you will probably have to trim this hose shorter), and the pump should pull right out. put the new pump in, with the new filter, and look at the bracket. you will see that the new pump is longer and the bracket needs to be modified. just drill a new hole a little above the old one on the bracket and it should fit now. now do the reverse of taking it out and it should all go back into place fine, but dont reconnect the return line. we still have to install the FMU. i might have forgotten something small but its been a little while since i did it. i followed the vfaq for the GS-T and it was pretty close to ours. here are the pics of the fuel pump being taken out and apart
____________________________
-Chris
