New2Dsms
- 91
- Nov 28, 2004
Kansas City,
Missouri
Ok i was driving home from work yesterday and while i was giving full throttle i heard my belts sqeaking then about 15-30 seconds later i smelled something burning so i pull over on the freeway and looked under the hood and there was smoke coming aroung the alternator/belt area
after that i noticed my interior fans werent working(heater and regular air) and my coolant and battery light were on the whole way home, the coolant and bat light is very dim though...I made it home no problem and i go to start my car this morning and the brake light stays on all the time (like bat and coolant lights) now but not as bright as when i pull the ebrake up..So now my batt, coolant and ebrake light stays on but very dim...I fixed the fan thing by replacing the fuse. Other than that all fuses checked out ok.
Note:Alternator belt was a lil loose so i tighten that but it didnt solve anything...
after that i noticed my interior fans werent working(heater and regular air) and my coolant and battery light were on the whole way home, the coolant and bat light is very dim though...I made it home no problem and i go to start my car this morning and the brake light stays on all the time (like bat and coolant lights) now but not as bright as when i pull the ebrake up..So now my batt, coolant and ebrake light stays on but very dim...I fixed the fan thing by replacing the fuse. Other than that all fuses checked out ok.Note:Alternator belt was a lil loose so i tighten that but it didnt solve anything...
