Quote:
Originally Posted by CanadianTSi
Your on the stock Injectors...set your boost at 15psi and leave your settings at 0.
I am curious as to why you feel you need to add 15% fuel at Idle???
It's amazing you haven't hit fuel cut yet adding that much air but let me repeat , Your on the stock Injectors...set your boost at 15psi and leave your settings at 0.
I agree with this 100%, set your boost as low as you can save up like 250 bucks and buy injectors then play with your afc.
Also your timing sucks, dont look at your 02 voltage look at your timing.
