View Single Post
Old 11-29-2004, 02:35 PM   #6 (permalink)
Cesar
Proven Member
Region: Southeast
Classifieds Rating: (0)
Reputation: Cesar is an unknown
I had about .003 taken off the head and about the same for the block. I used a mitsu metal head gasket which is about .057 if I'm not mistaking. The 8.5 comp pistons that I'm running balance out the comp ratio and give me a compression reading of about 165ish for all four pistons. I figure I can remove about .018thou off the head to get 180psi readings. What do you guys think??
Offline
Sponsored Links
