View Single Post
Old 10-03-2002, 01:56 AM   #15 (permalink)
98TsiAWD
Moderator
Region: Rocky Mountain
Classifieds Rating: (19)
Quote:
Originally posted by Otis
you gotta tighten the living #@%#@%#@%#@% out of those belts. I think the size is a 390k4. tighten the hell out of it. you should barely be able to move it. I dealt with that #@%#@%#@%#@% for so long. just loosen the bolt on the side first and then tighten the tensioner. its 12mm bolts. once the tension is set tighten the side bolt again and you're done!
The tensioner is as tight as it will go, I pulled the alternator towards the radiator by hand to the farthest position with no excess force. So Im thinkin my belt is too big. Stretched out maybe from someone making it too tight when they changed it?
Offline
Sponsored Links
