Tuned by Alex (boostdriven) yes flew in from Washington State to NYC and thanks to others
- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Autocross
- Road Course
- Mods-Bolt-on
- Turbo BorgWarner 300SX 88-75 63mm, .91ar TS T4 , ETS TS T4 exh mani , dual Tial 38mm Waste Gates, Tial Bov,ETS ultra short 4" race fmic and 2.5" pipes, 1g stock intake mani, Aero Motive afr, Walbro 400 lph fuel pump,AEM tru boost boost controller,ETS v band 3" downpipe, Redline Speedworx custom stainless 3" exh, Vibrant muffler, oil pressure gauge digital, fuel pressure gauge digital, Auto Meter digital water temp gauge, Fluidyne Radiator
- Mods-Engine
- Ffwd connection built 2.0l, Ross 40 over forged 9.0:1 Pistons, Crower rods ,Ffwd Connection Butcher knife edged crankshaft, Hole Shot racing ported and polished head 3 angle valve job ,Kelford 272,278 cams,AEM cam gears, Super Tech dual valvesprings, Kiggly HLA, Power Enterprise Kevlar timing belt ,Power Enterprise headgasket,JMF Billet RACE SMIM, Keltalon modded forward facing oil filter housing, fluidyne radiator, spal fans,mishimoto catch can -8 fittings
- Mods-EMS & Logging
- Ecm link v3 tuned by Alex(Boostdriven) ,PLX wide band ,AEM tru boost gauge and boost controller, Ecm link 5 bar map sensor, Autometer temp gauge digital,flex fuel system for E85
- Mods-Drivetrain
- Act ultra lite flywheel, Raif racing stage 3 transmission, South Bend Clutch their second most expensive Heavy Duty Kevlar clutch, Tmz throw out bearing and fork
- Mods-Handling
- Evolution 9 rear calipers and Stop Tech evo rear rotors, front Stoptech brake calipers and 13.0inch 2 piece rotors, EBCyellow stuff pads, 3G/2k+ (Galant same as Eclipse and Evo)brake master cylinder and brake booster, custom braided stainless steel brake lines all around, Road Race Engineering strut tower braces front and rear and Road Race Engineering under chassis brace, Eibach sport springs, Tokico illumina adjustable shocks, Suspension Technique polyurethane bushings all around, Enkei Rpf1 17x8.5 40 offset, R rated Bridgstone Potenza RE01s 245-45-17s, old school ROH rims for winter 17x8 with Contisport Ssr run flats 225-45-17
- Parts Wishlist
- Vented Carbon fiber hood, paint job,wish I knew how to build a bottom end myself and i wish i knew how to tune ECM link myself
- Background
- Road racing auto cross
