xleRateGSX
- 311
- 0
- Feb 17, 2002
Bay Area,
California
I searched and there wasn't a whole lot said about the install of the ZT-2. I also didn't get a green paper or instruction sheet in my box. I will raise a few questions here.
Will the boost solenoid work if you attach it to a vac line rather than install into piping? If no how did you go about the install into your hard pipes? Did you tap or weld a bung?
What drill size and tap is needed for the EGT?
What is the wiring instructions for the harness in a 1g. Pin # would be great if possible.
Thanks in advance.
Thanks in advance.
