Sleepr DSM
- 83
- 0
- Oct 15, 2002
Disclaimer: There are hard line folks on this site. If this is an ignorant post, delete it. If I'm posting in the wrong place, please move it. If I'm offending anyone, I'm sorry. I'm looking for suggestions from knowledgeable people who arent vultures about criticizing people who know less than they do.
I've been researching this for days. I'm getting a dual ball bearing GT30 series turbo. I'm set on a GT series 56 trim compressor wheel.
But, I can't decide between these two turbo's. (below) Can you guys help me decide. I KNOW that the majority of DSM owners run relatively small turbo's, so most of the responses may point me to the smaller turbo... Regardless, I'm still looking for your input. What would you go with.
I have stand-alone fuel management, 8.5 to 1 compression, 703cc injectors, a built bottom end, and a front mount intercooler in 3 months. My application is a daily driven car with AC, going to the track once a month. Lag has never bothered me in any turbo car I have ridden in. (up to 60-1 on a B18C-1 GSR)
I know.... why the hell can't I just pick one for myself?
From the many dyno charts I have studied on the net over the last few days, I'm guessing the GT12 will have what I call its M.B.P. (massive boost pull- or hit) from 3500 to 4000. I am guessing the GT14 is going to hit from 3800 to 4300, to as late as 4000 to 4500.
If some of the numbers below seem wrong or unlikely let me know.
What is your guess on spool? What would you go with?
Gt12, rated at 500 HP. I understand that if I subtract a hundred from those horsepower numbers, Ill be closer to what Im likely to achieve someday with every supporting Mod. = )
Part Number: 700177-0012
Turbine
Turbine A/R: Unknown
Turbine Outlet size: 55mm
Turbine Trim: 84
Compressor
Compressor A/R: Unknown
Compressor Outlet: 57mm
Compressor Trim: 56
GT14 rated at 600 HP
Part Number: 700177-0014
Turbine
Turbine A/R: .70?
Turbine Outlet Size: 55mm
Turbine Trim: 84
Compressor
Compressor A/R: 1.06
Compressor Outlet: 61mm
Compressor Trim: 56
Turbine
Turbine Trim: 84
Compressor
Compressor Trim: 56
Turbine
Turbine A/R: .70?
Turbine Trim: 84
Compressor
Compressor Trim: 56
