2G WOT Box not receiving TPS signal
Joewrechin
4
Aug 13, 2023
Chattanooga, Tennessee
Anyone here running a WOT box that can help me figure this out?
The issue I’m having is that when I first installed it and put turned the car on, the box was lighting up and when I pressed the brake pedal it would blink like it should (auto cars it’s brake pedal).
So I turned it over, it sounded like it was down a hole which they say will happen at first start up so I left it running till it cleared up then turned it off. When I went to turn it back on, the box stopped lighting up period, but the kicker is that if I unplugged the box from the car it wouldn’t start (which means it’s working properly).
After some digging and double checking it seemed that the TPS signal is not reading at all? What should I look for next?
