kspharris
- 478
- 5
- Aug 9, 2005
Goodlettsville,
Tennessee
In this thread, post 3, I have some questions on some wiring. I would post them there but I am not allowed to, yet . I want to wire a dual stage boost controller using my manual boost controller and BCS. If I connect my acc wire leading to my BCS to the "on" side pin 5 and power(12v) to the "off" side pin 5 then when I push in the switch it should activate the BCS, right? What about ground? I also want the switch to be illuminated as well. I either want it to illuminate normal (when I turn on the lights) or illuminate when I push the switch in. If I want it to illuminate normal, do I connect pins 9 and 10 (on and off side) to pins 9 and 10 (on and off side) from my factory hazard switch? If I wanted it to illuminate only when I engage the switch, would I run a jumper wire from my acc. wire to pin 9 "on" side?? If this is completly wrong, someone point me in the right direction. Thanks in advance guys, Keith.
