will these wheels and tires fit?
Eagle 5
380
Jan 26, 2003
Cincinnati, Ohio
rota subzeros 18x7.5 with 235/40/18 tires +46 mm offset i believe, with a 2" drop?
yes/no ?
what if i add 3mm spacers so offset would be +43?
Ya, the wheel well is huge for the DSM's, I can almost drop my car 3.5" with 18's on them... and still have a little room to spare.
yes/no ?
235/40-18 requires a minimum wheel width of 8.0" so it will not fit correctly
alright, so say i get wheels that are 18x8, what kind of offset would I need so that the wheels clear?
i knwo someone with 235/45/17 wheels with like a 7" or 7.5" width and his wheels fit fine, why wouldnt 235/40/18 fit on a 7.5 " width wheel? mees curious
tall tire..
While this may be different.. I had 15x7 rims on my stang. They had 225/60/15's on them. I went to 245/5015's fit perfectly..... just a thought.
I also had a set of 14x6 rims and they came with 195/75/14 and i went up to 215/60/14....
minimum wheel width for a 235/45-17 is 7.5" .... a taller side wall has more roon to squeeze down to a narrow wheel ....
18x8 with a 35mm - 40mm offset and you should be OK
  • For sale 1g 90 AWD trans
    90 AWD trans. Car has 113k. All stock. I have the engine which was mint inside. Trans has...
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Can ship padded USPS for $5. Message...
  • For sale 4G63 Machined alum shift knobs
    Machined alum shift knobs. 4 inch height. Threaded. Well made. Thinking these are over 25...
  • For sale 2g 2G AWD E Brake Cables
    2G AWD E Brake Cables $50 + shipping and paypal feesYou must be registered to see element.You...
  • For sale 2g 2GA AWD Auto Swap
    2GA AWD Auto Swap $1,900*** pick up in 08080 NJ **** Nothing is being separated at this...
