ryan's rs
- 0
- Sep 1, 2010
lexington,
Missouri
I have a 420a motor bored .20 over already bought it like that, the person i bought it from did not run it with a mega squirt. then i bought a mega squirt installed it and it ran fine for 6 months then i heard a lower end noise in the motor when going over 1500 rpms. then pulled the motor and found out it was the fly wheel cracked all the way around where it bolts to the crank. But while the motor was out i went a head and pulled it a part to make sure. then found out the pistons where melted on one side of them from running to lean because of not having the mega squirt from the owner before me. Now i have the motor at the machine shop and found out he had the block bored .20 over already and was wanting to know if it was ok to go .40 over or just let it get honed and have .005 to .010 thousnads of an inch off. Will the rings seat after the honing or not? This motor has a turbo and i was running 20lbs before and will be running 35lbs after the rebuild. Yes the head is built already just need to know if i should hone it or bore it. Thanks
