1G Wideband question
bryanzomg
176
20
May 18, 2015
melrose park, Illinois
my car has narrowband simulated through link and I have a AEM wideband hooked up to ecu. If my wideband sensor is taking a crap will this cause the car to run like crap as well??
You kinda need to define that though. Bad o2. Ecu doesn't know what to do so it will default rich. WOT ecu doesn't look at o2.
So what does " run like crap" mean
Crap “loss of power randomly”. I don’t have 02 sensor it’s being simulated through LINK. Only have the 02 for wideband hooked up
I don't think you understand how this works. Ecu can't use a wideband input. Ecmlink allows you to take the wideband input and "simulate" narrowband.
Random loss of power? Probably not.
How do you know wideband is going out? Logged it?
The wideband reads completely lean under any load, OR it’ll read 13.3 constantly under any load or it’ll be erratic jumping around rapidly.
During partial throttle the car will almost “bog down” is the best way I can explain it
Sensor is likely dying based on what you describe. As previously mentioned, when the wideband is your only o2 sensor you're relying on it for your fuel trims.
