dsmdeliveryboy
- 2,054
- 5
- Aug 14, 2007
Medford,
Oregon
yes sir i did change the wasgate, tight all my bolts again and fix all my boost leaks. then i got off work, and did a pull blown turbo no boost and alot of smoke, i did check the exhaust no oil dry then i took the intake pipe and the bolt came off with the shaft. next day i took it a part and found out that the shaft broke and that the oil ring seal on the shaft was deformed, but it did not leak oil all the smoke was to metal and burning smell.
Were you running a restrictor?
