where to get a new 6 bolt cylinder head
91tedralon
57
Feb 10, 2003
both of my exhaust valves got burned out on my #3 cylinder and i have no compression on the cylinder. :mad: anyway, i figured getting a new or rebuilt head would be cheaper (and probably better) than having my mechanic dissasemble the whole thing just to replace 2 valves. does anyone know any websites that i could get a new or rebuilt cylinder head? any replies would be appreciated. thanks
It would not be cheaper to buy a new head. Replacing two valves is a pretty easy job, it shouldn't cost more than $200 including the new valves. As long as there is nothing wrong with the head itself, I'd do it that way.
With labor, once the head is off. The valves are only about $16 a piece. It takes about 10 minutes to change one on a workbench with the proper tools. Call a machine shop in your area to verify the exact price.
if you do it yourself, standard size stainless steel replacement valves are $8 a piece @ RRE. a new headgasket kit if needed, the valves, and any other problems you might encounter with a DIY job, i would guess somewhere between $200-$300 DIY. a mechanics labor fee, i would have no clue... just don't call Mitsubishi, unless you're trying to figure out what the most amount of money you will ever spend on replacing 2 exhaust valves is.
You're saying 2-300 with gaskets and everything else needed for the job. We're only talking about prices for the head alone, not the whole job. Even if gets a brand new head, he'll still need a head gasket. I say $200 to replace the valves in the old head. This price has nothing to do with anything else. If you do it yourself, the price will only what it costs you for the valves.
  • For sale 1g 1993 Eagle Talon TSI AWD
    1993 Eagle Talon TSI AWD $9,500- Clean Title in Hand ( in my name ) - 95,600 miles ( 3,600 on...
  • For sale 4G63 1G OEM Knock sensor
    1G OEM Knock sensor Came off a running car$85usd shipped Lower 48/Canada
    • Dsm_canadian_mike
  • For sale 4G63 Waterline sets with bolts
    Water line sets. 45 deg and 90 deg in each pair. With banjo bolts. . Have ten sets like this...
  • For sale 4G63 1g cy head with 2g intake ports
    1g style cy head. Bigger end studs on exhaust port. 1g Waterneck. 2g intake ports. Great cy...
  • For sale 1G OEM BOV COVER- Darth Vader hat
    As title states, help complete that full OEM reproduction look. Buy it here...
    • ist dwa
