wheel hop
animal1
Feb 13, 2003
i have yokohama tires, KYD-GR2 struts, pro-kit springs, and a reacive strut bar and she still wheelhopps on hole shot what else can i do?
Here is my suspension set-up which seemed to eliminate most of my wheel hop.
- Tokico Illumina struts (adjustables)
- Eibach Pro-Kit
- Prothane motor mounts
- Front strut bar
- Front lower strut bar
- Rear strut/harness bar
- Rear lower strut bar
- Kumho tires
You might try getting adjustables struts, and prothane motor mounts. Also, tanabe also makes badass front and rear under braces. You can check them out at optionautosalon.com. Hope that helps!
Get a strut combo that allows you to adjust them, so when ur dragging you can set the front to as soft as they go, and the rear to the stiffest.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
