Zerocygnal
- 641
- 1
- Jul 1, 2002
Springfield,
Ohio
Okay this is a new one on me for DSM's, I only had this problem with Mustangs and never one an AWD system.
If at any time I step on the gas fully in first, second or third the Right Rear wheel breaks loose traction and starts spinning like it has more power to it than the others. This is the damndest thing and I can honestly say I have never seen such a thing in this type of car...especially while it is already rolling!!! While the wheel spins that side of the car shakes violently. I checked the strut, the swaybar connection, the bolts on the strut, the control arm bolts. The only thing I did notice is that there was alot of play in the drive shaft carrier bearings. Like you could move it up and down an inch or more. IS that normal for these cars, or are the carrier bearings worn out???
Jeeze now I can tack that onto the 1500RPM idle that started once it got cold outside tonight...
Someone please tell me the rear diff didn't just take a crap...
Thanks in advance
Thanks in advance
