1. Join the Community!
2G What wheels fit with the brembo brake kit?
Posted by Behnam, Jun 10, 2020
Please Support VR Speed Factory
Please Support ExtremePSI
  1. Behnam
    Behnam Proven Member
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    Hey, my 2g Eclipse has upgraded to Brembo brake kit and the front calipers are pretty big so i have a huge problem finding wheels that fit. anyone else know or has brembo brakes in the front that knows what wheels fit?
    Street Build 178  1
    1997 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  2. Kryndon
    Kryndon Proven Member
    628
    312
    Joined Jan 10, 2014
    Bulgaria, Europe
    The stock EVO 8 Enkei wheels fit perfectly. They are 17"x8" and an offset of +38mm. So if you look for other wheels with similar specs, they should fit.
    Street Build 4K  12
    1997 Eagle Talon TSi AWD
    13.43 @ 99.7 · 2G DSM
    Loading...
    Behnam likes this.
  3. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    tbh i was really looking at the XXR 527 i want somthing like those not really a fan of the Enkei wheels
    Street Build 178  1
    Loading...
  4. Kryndon
    628
    312
    Joined Jan 10, 2014
    Bulgaria, Europe
    Well I just googled "XXR 527" and on this one website they have them in a size 17x8.25" 5x114.3 and a +35mm offset, which should fit fine. Compared to mine, yours will sit the same distance inside the fender (inset) but will poke out an additional 6.2mm. If you put a fat tire on them, it will definitely poke noticeably, which isn't necessarily bad for some but I know some people don't like tires and wheels that stick out. Additionally, some countries have laws that do not allow wheels/tires to poke outside of the fender and stock dimensions.
    Also you don't *have* to go with the EVO wheels but I'm just saying they are the most common swap which works great with bigger brakes.
    Street Build 4K  12
    Loading...
  5. ec17pse
    ec17pse Freelancer
    4,818
    1,978
    Joined Nov 1, 2008
    London, UK, Europe
    Firstly those are not evo brembos! Do you know exactly what brembos they are from? As these are radial mounted vs the normal ear mounting the evos use. So for this its going to be tricky as the caliper may sit further out in either height for a bigger rotor size or offset tonthe hub.
    Can you give us anymore info on the calipers at all?
    Road Race Build 11K  10  57
    175 whp · 180.1 lb/ft · 2G DSM
    Loading...
  6. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    Tbh the previous owner installed them he said somthing about them being porsche brembo's
    Street Build 178  1
    Loading...
  7. ec17pse
    ec17pse Freelancer
    4,818
    1,978
    Joined Nov 1, 2008
    London, UK, Europe
    Best bet is to measure the hub to caliper surface to confirm you get the offset right for the new wheels
    Loading...
    Kryndon and Behnam like this.
  8. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    So if i measure the hub to furthest part of caliper and lets say as a example i get 20cm how do i measure that with the offset? i really dont understand how to read offset haha
    Street Build 178  1
    Loading...
  9. ec17pse
    ec17pse Freelancer
    4,818
    1,978
    Joined Nov 1, 2008
    London, UK, Europe
    You can use any online wheel calculator to get a good idea of offsets your able to use. Start off with the evo enkeis and mess eith the offset but also consider spoke design as not all offer clearance for bigger calipers
    Loading...
  10. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    Alright thanks, yea had 5cm from hub to caliper using spacer atm to get thiese wheels to fit
    Street Build 178  1
    Loading...
  11. ec17pse
    ec17pse Freelancer
    4,818
    1,978
    Joined Nov 1, 2008
    London, UK, Europe
    The front of the caliper dont look like a porsche caliper? They are quite square faced so this radial caliper is a weird one for me
    Loading...
    Behnam likes this.
  12. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    After a bit of googling it really looks like the Porsche 933TT brakes tbh
    Street Build 178  1
    Loading...
  13. ec17pse
    ec17pse Freelancer
    4,818
    1,978
    Joined Nov 1, 2008
    London, UK, Europe
    They do seem to match the pictures so good finding that,
    Loading...
    Behnam likes this.
  14. Dreams Realized
    Dreams Realized Proven Member
    225
    82
    Joined Jul 23, 2018
    Seattle, Washington
    Consider spoke design as the forefront of your search. I would start by verifying you actually have porsche 933TT they usually have a serial number printed on the side or the back. Since it seems the previous owner painted the calipers with ceramic paint this may be hard. Then figure out what wheels came stock with those brakes and work from that measurement.
    With different brembos the biggest thing is finding a spoke design that arches outward from the hub as you may find face clearance to be the hardest hurdle to overcome. XXR seem to fit that description.
    My shelby gt350 rims have 0.25" face clearance in freedom units and plenty of side clearance
    Street Build 1K  4
    awd · manual · 2G DSM
    Loading...
    Ludachris and Behnam like this.
  15. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    Thanks alot very helpfull!
    Street Build 178  1
    Loading...
  16. Behnam
    45
    13
    Joined Apr 15, 2020
    Fredrikstad, Europe
    Was really looking at thiese with ET45 in the front and ET30 in the rear both 8.5 you think that sounds alright? Skjermbilde.PNG
    Street Build 178  1
    Loading...
  17. steve
    steve DSM Wiseman
    13,556
    678
    Joined Feb 3, 2002
    Boulder, Colorado
    It's all about the shape of the wheel spokes inside the rim/wheel.
    180  4
    2008 Audi TT 3.2 Quattro Roadster
    awd · manual · Misc Vehicles
    147  5
    2002 Audi TT Quattro Roadster 225
    157  2
    1992 Dodge Stealth RT/TT
    awd · manual · 3000GT/Stealth
    4K  12
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
    Mello and Behnam like this.
  18. Mello
    Mello Proven Member
    1,161
    338
    Joined Jul 4, 2003
    Albuquerque, New Mexico
    Buy wheels that say they fit EVO's and they should also have enough clearance for Brembo's on a DSM.
    Dusty Landrum likes this.
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
