1LE
- 1,347
- 4
- Aug 1, 2002
Sylvania,
Ohio
MNGSX said:I have some aero ideas but he said machine shop.. Glass, CF or ABS are not their usual materials..
So much for my full CF suspension idea
Note: This feature currently requires accessing the site using the built-in Safari browser.
B005T3DT5i said:a full line of block off plates , like a kit, that has block off plates for anything you want to block off......
MNGSX said:When the flywheel gets pulled instead of pushed = less chance of walk.... Ever hear of EVO walk?
na90dsm said:fidanza has em. or just swap to a gst setup
jott5555 said:What would you want to block off other than the egr and fiav?
i think a good quality turbo manifold at a decent cost would be a decent idea. or a battery relocation kit that includes wire, box, fuse's, distribution box's and external kill switch.. that would be a good idea
Raph said:so a gst flywheel iwill fit a na?
oh,a company here makes nt cams for the 4g63.. but its 570 euros for the set w springs and ive heard that theyve got problems ( cams are cheap,get run in after 20k)
why not start by making some oil and radiator caps that the DSM or 4g63 or something simple to begin with
Morphius said:Explain?
FourG63 97GST said:Aluminum door handles
MNGSX said:Preliminary
Its not just MT's and DSM's
MNGSX said:So if the clutch pulls on the pressure plate it opposes this force and actually decreases thrust bearing wear.
Morphius said:Does the EVO 4-8 have a TB that is attached to the pressure plate? and is acutated by pulling it?
I've yet to see such a clutch, but that doesn't mean it doesn't exist. Do you have a pic?
MNGSX said:Yep... Stock throwout bearing design on the EVO's
RRE said:You will need to resurface the flywheel or get possibly get an aluminum flywheel. With the DSMs you will hear of horror stories of difficulty getting the flywheel resurfaced to the correct step height. That is a DSM thing only. EVOs use a flat flywheel with no step. While you will still want it done at a machine shop that knows what the hell they are doing, it isn't super critical like the DSM guys had to deal with.
