Please Support Rix Racing
Please Support STM Tuned
Resolved 2G What is this? Cruise Control Vacuum Pump
z_tune
Nov 3, 2011
Fort Collins, Colorado
Not my car but can anyone tell me what this is? Mine is all corroded and just wondering if it needs replaced.
I just googled a 2g engine bay for the pic. My cruise does work however I'm having some low idle issues with intermittent surging. Could this be the cause?
I'm pretty sure the cruise has nothing to do with your idle. Why don't you just delete the cruise and have a cleaner engine bay rather then replacing it? But, if you use the cruise i would simply replace it :rocks:.
I think you have a different problem. Cause when the cruise is off then it should act normal. I guess it could cause idle issues but not surge. Try adjusting the cable. But I'd it don't work then why not replace it with a non cruise cable to clean up the bay)
Thanks guys I've been trying to figure out why my idle is acting funny then I saw a bunch of corrosion there. I think I'll take it out since I never use cruise anyways.
ISC maybe? ISC is an Idle Speed Controller and are easily mess up.
Ah my mistake guys! I was looking at my engine earlier and the part that is corroded is right under the cruise control I circled. The corrosion was so bad it was all over that too! So I'll ask again does anyone know whats directly under what I circled?
If the system works as designed, don't replace any components. Even if it looks like its been sitting at the bottom of the river. If it works, allow it to continue until it does not.
My cruise control didnt work, and my idle was slightly high. In your first picture, follow the cable you circled to that black box. That contains your throttle cable. Spray that down with wd-40 while pulling on the throttle and pull on the wire to the cruise control. If that was your problem youll notice a gas softer pedal, and it -may- help your idle, it worked for me. Im writing this because you speak of mass corrosion and this could be it.
