420A What 420a manual transmission fluid can i use?
I never ran anything but the chrysler approved fluid. It's the one that says nvt-350 on the body. I personally would never run anything else. The slightly higher cost is worth the piece of mind. IMHO
I bought some 6 months ago and it was 26 a quart.
1st and 2nd are brass syncro's, the rest are paper lined.
i use mopar manule transaxel fluid.
never had a grind ever. in this car with 170k miles
or in my old 400+ hp one
Indeed, but the stuff was becoming hard to come by. Chrysler recommended ATF+4 as an alternative, and if you can't trust them, who can you trust?
Anyway, Modern Performance recently started carrying the original Mopar fluid. It's $44 for 3 quarts -- not too bad:
Mopar T350 Manual Transaxle Fluid - 00-05 Dodge Neon Drivetrain Parts, Clutches, Axles, Short Throw Shifters, Booger
I wanted to add here that on my manual transmission, there is a label that says to use ATF+4. I removed the fluid and that is exactly what came out. my transmission is also the NVT-350.
Interesting. I've never seen that before. Maybe somebody added it at some point.
Sorry I remembered I swapped out the 2g eclipse trans for a neon trans from an 2000s model. Makes sense why there was a label since the trans was newer. Well to reconfirm this one had a label for atf+4.
I talked with my roommate, that has a neon he says he's been using synchromesh in his neon. His is a 95-99. He drives it pretty hard. Ill need to ask him how long he's been using it, but he's saying the atf+4 and synchro mesh have a lot of the same ingredients that are required for our transmissions and thats why he uses it.
Amsoil synchromesh is what I used for years. Used it while I autocrosed back in the day, went on countless road trips, and daily driving (I still use it and never had a problem at -40* F up here on startup and daily driving); never had any complains with gear shifting or noise. It was cheaper than the mopar transmission fluid that dodge was selling at the time. For whatever reason I think I remember reading articles about atf and our synchros not being compatible or something. I could be completely wrong, but the thought comes to mind.
