well.. this might be my HP rating...
siueclipse
1,548
6
Sep 11, 2002
If I have setup my rev speed meter correctly, (which im sure i have cause ive gone over it time and time again), and if i have my calculations correct.. i should be around 365whp at 15 pounds of boost. like i said.. this is only an "I think" however the car feels like it. still running very rich at higher boost levels because of the crappy cartech fpr.
ill go to the dyno sometime soon so i can see if im correct.
James
Not to burst your bubble or anything, but you wont be anywhere near 365whp with only 15psi unless you are spraying on top of it. id guess closer to 300whp. unless you have the HRC kit, in which case it will probably be closer to 280-290whp. Dino(at 2gnt) dynoed at 15psi and he has LOTS of headwork to go along wth it, and made just pver 300whp. not trying to be an ass to you or anything by any means, just dont go to the dyno expecting 365whp, cause im afraid you will be real disappointed.
That was with a T3/T4. 20g or not, 15psi is gonna get you around 300whp, which isnt damn bad at all. Armond put down 400whp with his Avenger and a 20g, but he has a standalone and was running upwards of 25-30psi.
Dino and Armond has all those ^^^ mods, and then some. its all about tuning really. a properly tuned 420A at 15psi should make anywhere from 300-325whp. ive saw lower(275whp) and ive seen one or two higher than that. i just wouldnt want ya to get your hopes up for 365hp and be disappointed. goodluck with it though man. let me know what you dyno at when you do.
Armonds car has crazy amounts of cash in it :) Also I think he ran 338hp at 18psi.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
