Welded Center diff vs TRE spec center diff spool vs ..etc.
They all have very different functions...
What are you looking for and what is your purpose for wanting one of these. Tell me a little more fella'
I am not AWD so can't tell you very much, But I do know this..
I have a freind with a 97 GSX who way back had the transfer case replaced by a shady mechanic.
he has since broke 3 TRE built trannys with QUAIFE center diffs.. the diff broke every time. .
he put a SHEP buitl tranny in with a welded stock center in it and within a week the T-Case broke..
come to find out the car had the wrong transfer case in it the whole time it was from a different year which was a different gearing, causing the rear tires to try and turn at a different speed from the front tires.. Thankfully Shepard let us know what had happened and hooked my friend up with a good deal on a new output shaft since it was destroyed too..
SO from this I can tell you a quaife is not a very strong differential it broke three of them because the t-case was putting excessive force on it all the time.. the welded center diff. was strong enough that it broke the t-case instead it it breaking..
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
