Boostedtsi0521
- 2
- Feb 27, 2017
miami,
Florida
So like the the title reads it is super weird what's going on. To begin with the car was not starting, I was driving and all of a sudden shut off. Fuel pump was bad so I changed it for a higher flow (255lph) pump and install an air fuel pressure regulator (afpr). I crank the car and it doesn't turn on and psi is at 43. I can smell the gas so I disconnect the pump and crank it and it turns on stays on for about 10 seconds before it shuts off. So I'm guessing it floods the cylinders with gas and when no gas is coming in it turns on. How is this even possible when my psi is correct? I'm all out of ideas I checked the injectors and they are firing correctly. I have spark and fuel pressure .If anyone has heard of this please let me know
