Kingdom
- 366
- 0
- Jul 19, 2002
Adliya,
I purchased a 6-bolt motor for the swap that will never probably complete.
its hard to come buy a 4g63 turbo down here. So I went to the junk yard and found this Silver 91 Galant Turbo. All the tags were removed so I dont know about the origin(spec) since they were never sold here. The wiring plus ecu was all removed, no CAS
. anyways I have had the motor in my garage for a long time, but I just recently had time to disassemble it.
first thing I noticed when removing oil pan that their were no balance shafts. removed oil pump and it had a plug in place of the balance shaft gear that I have never seen one like before. It wasnt metal, it looked like a factory piece. It looks different than the factory piece on vfaq.
One balance shaft had the stub just like Vfaq and the other wasnt their, but the bearing was blocked no whole at all.
Finally it didnt have any oil squirter, just bolts in the place of the oil squirters to block it.
Is this normal? was it done or factory?
Iam definitly leaving the balance shaft setup the way it is, but what should I do about the oil squirters?
should I buy a set and put it on, or just leave it the way it is? any danger in not having squirters? shouldnt removed squirters result in higher oil pressure?
