Ways to remove winshield vinyl?
whitegst
53
Sep 26, 2002
Austin, Texas
Does anybody know which is the easiest way to remove the vinyl sticker from the windshield? I had it on for a couple of years but coudn't get it off quiet easily. So if there is a product/solution that you know would help me to get this thing off w/o damaging the winshield, then let me know.
my friend owns a sign shop.... heres what to do. heat it up with a hiar dryer, a lil at a time, and scrape off, but use a plastic scraper so you dont scratch the glass.
it will crack your windshield if its to hot. happen to a freind. try goob be gon, something like that.
i went to my local graphics shop. picked up some industrial citrus adhesive remover and used a razor to get the sticker off, then sprayed the cleaner on, let it sit for 20 mins and wiped off and repeated like 3 times to get it all off.
Get a few plastic putty knives if you're not experienced in using razors on glass- you can scratch it. Sharpen up the plastic, it'll be almost as good, and won't scratch.
Thanks guys, for your advises. it's hot here in TX, so i won't be needing a blow dryer... but man, i didn't know it would be this hard to take it off. Assuming that it would take me days to get it all off. f***! Never gonna put the damn things on anymore.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
