Sephroth57
- 1,388
- 0
- Sep 7, 2002
Barnegat,
New_Jersey
So yeah, theres coolant spraying/leakin out of my water pump right behind the belts, and it got everywhere and wont hold fluid.. this is probably just the seal leaking but i might as well replace the pump if i have it off right?
now the problem is i was planning on an engine rebuild in a few months, so to get to the pump you need to take off the timing belt, which if you take off you should probably replace. is it ok to take off the timing belt, and put the same one back on if im not gonna use that engine for more than a few months. i plan on 6 bolt swapping so i wont even have the same engine in there so, it would be a waste of money
opinions?
opinions?
