reborn750
- 106
- 1
- Oct 7, 2010
Brookings,
South_Dakota
I installed my walbro 255 lph pump in my 420a eclipse. hooked everything up correctly, plugged it in and bolted the pump cover back down. Now when i turn the key on the pump kicks in but only for a couple seconds then goes quiet. i thougt my fuel pressure regulator wasnt working so i pulled off the pump side line. Now even with the fuel line not hooked up and i turn the key and the pump kicks in it wont pump anything out of the exposed line. but like i said the pump only comes on shortly for a few seconds. Does the car need to be running? do i need to be cranking the car over or do i just need the key on? did i do something wrong?
