SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
I wanted to pass this along as it was brought to my attention. Most guys , if not all guys running this transmission are using the standard shift kit offered and have the line pressure adjustment either maxed out or nearly maxed out along with the reducing pressure. When they logged the line pressure they were seeing 150 psi Max. According to Kiggly for guys making decent power you should have at least 200psi. They decided to add a 4mm shim and will be taking the car out later. I’m Interested to see what the pressure is after this adjustment.
