1. Join the Community!
violent shaking when taking off in first gear
Posted by RNR_MOTORS, Apr 14, 2011
Please Support Feal Suspension
Please Support STM Tuned
  1. RNR_MOTORS
    RNR_MOTORS Probationary Member
    24
    Joined Feb 9, 2009
    novi, Michigan
    I just finished my clutch upgrade i went from a 2600 act to a 6 puck sprung act the issue im having is when im taking off in first evverything under the hood starts to violently shake like if my motor mounts were broke. but once up and rolling its fine any ideas is it the clutch and i just gottta change the way i take off. fyi this is taking off normal driving :hmm:
  2. forcdndukshun
    forcdndukshun Probationary Member
    24
    Joined Mar 24, 2009
    eugene, Oregon
    If everything is adjusted right, slave cylinder and rod. I would say that it is the new clutch. I know that a six puck is pretty harsh it's either in or out. It's usually not the smoothest on take off. That could be the difference.
  3. RNR_MOTORS
    24
    Joined Feb 9, 2009
    novi, Michigan
    yea, im still trying to get the whole rod adjustment thing going ive been having issue with that too. but thats i figured that its the clutch, it had me double checked every bolt i was thinking something was loose or i forgot something :aha:.....hopefully thats it ive tried to read on all the adjustment guides and evevn saw that video on youtube and its not that easy.
  4. forcdndukshun
    24
    Joined Mar 24, 2009
    eugene, Oregon
    I agree. How is the engagement? How far is the pedal off the floor when the clutch begins to engage?
  5. RNR_MOTORS
    24
    Joined Feb 9, 2009
    novi, Michigan
    its about halfway where i think should be but just doesnt feel right. and if i adjust the rod some more it gets better but the thing is after driving it makes the clutch grab all the way up like if it was burned. so im thinking i have to bleed it some more. the slave and master are brand new. this whole adjustment part of it has always kick my butt. my first gen the same thing was going on and i just gave up and brought to shop to have it done. I almost to the same point LOL
  6. Yiddie
    Yiddie Probationary Member
    10
    Joined Jul 27, 2010
    Brainerd, Minnesota
    I had the same clutch act 2600 heavy duty 6 puck sprung, and I was having the same issues and I mean the shake was BAD getting into first or reverse. Changed to a street disk, Car is just fine now.
    295  0
    1998 Mitsubishi Eclipse GSX
    · 2G DSM
    Loading...
  7. boostedinaz
    boostedinaz DSM Wiseman
    2,320
    16
    Joined Dec 22, 2002
    Scottsdale, Arizona
    Sounds like it is clutch chatter. From what I have seen this is going to happen with a pucked clutch more than a full face clutch.
    413  0
    1991 Mitsubishi Galant VR-4
    manual · Galant VR-4
    Loading...
  8. RNR_MOTORS
    24
    Joined Feb 9, 2009
    novi, Michigan
    so ive been doing alot of asking around about this issue pretty much is the price you pay when you want a real clutch the only way to make it stop shaking is by slipping the clutch out about 3500 rpm yes that high... so its just the clutch being a badass LOL thanxs everyone and i hope this helps someone in need LOL:hellyeah:
  9. donniekak
    donniekak DSM Wiseman
    4,692
    913
    Joined Mar 23, 2008
    Surprise, Arizona
    Why would a post i made in the local sub-forum disappear?
    Street Build 4K  0
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  10. butlersdog
    butlersdog Probationary Member
    Joined Apr 7, 2011
    Oak Grove, Missouri
    Try to fix it up or bring it to some good phoenix auto repair shops in order to have the remedy on that one. I hope that you would take consider of it in order to make your ride safe and sound. A lot bigger problem will occur if you would just set aside that one and see that things would act up very wrong in order to really see the real problem there.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
