ErikTande
Supporting Member
- 1,508
- 569
- Dec 17, 2012
Centennial,
Colorado
How far should the slave be moving? It's moving less than 15mm for me (see vid).
- Brand new clutch, flywheel, slave and master.
- stainless steel clutch line
- The fork is not hitting the bellhousing (see vid)
- Clutch engages RIGHT off the floor.
- Clutch is bled properly.
- Master is adjusted all the way out (only way to get the pedal to feel normal)
- Clutch drags at 7000 rpm, no less. (see vid)
Worn out pedal assembly? How do I check that?
How I feel:
Here's a video of the slave movement and clutch dragging.
How I feel:
