dudeX
- 126
- 12
- Jun 14, 2011
Surprise,
Arizona
Does anyone know if a turbo from an 07 STI (VF43 I believe) can in any way be used on a dsm? I'm curious because I have access to one and want to swap out the t25. Thanks.
Note: This feature currently requires accessing the site using the built-in Safari browser.
If your a master fabricator you can utilize reverse rotation too .If you are a master fabricator then yes, you can use most turbos if they spin the correct direction. Is worth the time, money and hassle? No.
Wrong, dude. That would be a Grand Master fabricator.If your a master fabricator you can utilize reverse rotation too .
