turbotalon02
- 0
- Jan 8, 2003
ok i need some help i have installed a 20g turbo, turbo xs type h bov, act 2600 clutch, profec-b b/c, rc 550cc injectors, walbro 255lph fuel pump, stillen adjustable fuel pressure regulator. when i put on the injectors and afpr it ran better but i could feel it starving for fuel but then i installed the fuel pump and when the turbo spools up the power dies and it just loses power. now with the fuel pump i lost the spacer that came with it that goes on the fuel fitting below the o ring and plastic seal so i used another o ring. i dotn know if this is the problem of what. but it started doing this after installing the fuel pump. i am getting 38 psi of fuel to the rail what psi shoudl i put to it? i have no clue and also wta the hell do i do abotu a logger or air fuel controller. will that fix my problem if so how the hell do i know how much fuel to put to it in 500 rpm increments. how do i knwo what will work the best? it seems a little advanced for me but no one has explained it to me in detail. i have never played with one. i am a bolt on type of guy. i want to bolt it on and go. somebody tell me what i need i am sick of this car! ugh i have all the parts on it for the car to have massive potential i just need one cruical thing to fix it. i dont know if my computer is not reading this or what. if i need a logger or air/fuel controller will someone please explain to me how to use them and which is the cheapest and best ones to go with. i just want my car to run right. i want to know what to buy that will fix my car and make it run bad ass and i am sick of spending all this money with no results! please help!
