1. Join the Community!
Valvoline Engine Guarantee
Posted by Black91TSiAWD, Sep 22, 2009
Please Support JNZ Tuning
Please Support STM Tuned
  1. Black91TSiAWD
    Black91TSiAWD Proven Member
    171
    Joined Nov 30, 2004
    Binghamton, New York
    Im thinking about signing up for this. Seems pretty legit and they dont seem to be hiding anything to do with whats covered and what isnt. Pretty straightforward rules, and with their 1k mile grace period I could just change the oil in my camry every 4k instead of 5, not a huge deal for a free engine if it ever blows.
    I dont think ive ever really used valvoline oil before but now I might just start, apparently they think pretty highly of it.
    308  0
    1990 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  2. phunny
    phunny Proven Member
    1,652
    17
    Joined Feb 1, 2005
    Pittsboro, Indiana
    It looks legit. It doesn't say they won't cover rotaries either. They'll revise that at the 19 month point. :D
    Street Build 1K  0
    1999 Mitsubishi Eclipse GSX
    manual · 2G DSM
    926  0
    10.500 @ 134.000 · 2G DSM
    Loading...
  3. chico904
    chico904 Proven Member
    1,094
    3
    Joined Feb 9, 2004
    Pittsburgh, Pennsylvania
    I'm not really clear on what they are covering. Are they saying that they will cover your engine if it fails due to oil breakdown?
  4. Black91TSiAWD
    171
    Joined Nov 30, 2004
    Taken from the FAQ.
    WHAT PARTS AND COSTS ARE COVERED UNDER THE GUARANTEE?
    The Limited Engine Guarantee covers most lubricated engine parts. These parts include pistons and rings, turbo bearings, cylinder linings or bores, oil pump, rods and rod bearings, valve stem and guides, cam shaft and bearings, crankshaft and bearings, valve lifters, rocker arms and pivots, distributor drive gear, and timing gears or sprockets. Valvoline will cover the cost of labor and replacement parts (or replacement engine if necessary) to restore your engine to operation. However, this Limited Engine Guarantee does not cover parts related to electrical, fuel, computer engine management system, cooling system, air intake system, exhaust system, timing chain, turbocharger or supercharger.
    IF MY ENGINE FAILS, WILL I BE REQUIRED TO PROVE THAT IT WAS VALVOLINE MOTOR OIL THAT CAUSED THE FAILURE?
    No. Unlike other so-called guarantees, we believe so strongly in the quality of our products that we will cover engine failures even if they are not caused by our product.
    Seems like win if youre already buying oil anyway, might as well get some sort of coverage with it that is basically "free", cause youre gonna buy some sort of oil regardless.
    308  0
    manual · 1G DSM
    Loading...
  5. Black91TSiAWD
    171
    Joined Nov 30, 2004
    gasoline powered passenger car, Id say youre covered. :thumb:
    308  0
    manual · 1G DSM
    Loading...
  6. GofaST4life
    GofaST4life Proven Member
    800
    126
    Joined Oct 21, 2007
    Medina 44256, Ohio
    almost sounds to good to be true
    2K  0
    1997 Mitsubishi Eclipse GSX
    manual · 2G DSM
    Loading...
  7. Lofty
    Lofty Moderator
    1,438
    32
    Joined Jul 27, 2008
    Waukesha, Wisconsin
    It's a gimmick. Who's body lasts up to 300,000?
    Very few. Specially up here.
    767  0
    1991 Mitsubishi Galant VR-4
    manual · Galant VR-4
    Loading...
  8. Black91TSiAWD
    171
    Joined Nov 30, 2004
    I dunno, I see alot of cars of all makes with over 200k on them, youd be surprised what semi-regular washing and some rust repair every now and then will net you.
    In NY, especially here in the snow belt they salt like crazy so dont give me that.
    And you more than likely wont hit the 300k with most cars, but thats a good ceiling for the coverage considering most cars pop by then.
    308  0
    manual · 1G DSM
    Loading...
  9. vinnio
    vinnio Proven Member
    213
    Joined Aug 12, 2007
    Duluth, Minnesota
    I rebuilt my engine about 10k ago and have only used valvoline. Think they will cover a rebuild?
    335  0
    1996 Eagle Talon TSi AWD
    automatic · 2G DSM
    Loading...
  10. Black91TSiAWD
    171
    Joined Nov 30, 2004
    I think as long as the car itself has under 75k miles and was rebuilt using stock internals, youd be good to go.
    308  0
    manual · 1G DSM
    Loading...
  11. Defiant
    Defiant DSM Wiseman
    25,196
    145
    Joined Jan 13, 2003
    glorious Galt, California
    Engine parts don't fail because of oil. They fail because of a lack of oil, which isn't the oil's fault. Send us a sample of oil from the failed engine, we'll run it through the lab and let you know.
    Gimmick.
    3K  0
    1995 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  12. 99gst_racer
    99gst_racer Moderator
    9,053
    815
    Joined Apr 5, 2003
    Coloma, Michigan
    That's pretty crafty. They can cover all of our turbo bearings that aren't related to our turbocharger... :rolleyes:
    I've been happily using Valvoline oil for many years, but this marketing crap is for the birds.
    Street Build 6K  67
    1999 Mitsubishi Eclipse GST
    609.8 whp · 541.2 lb/ft · 2G DSM
    Loading...
  13. Black91TSiAWD
    171
    Joined Nov 30, 2004
    but if any lubricated internal part fails while youre using valvoline, they say its covered.
    Things still fail even with the correct amount of oil.
    308  0
    manual · 1G DSM
    Loading...
  14. Black91TSiAWD
    171
    Joined Nov 30, 2004
    All that means is they wont buy you a new turbo, but they would rebuild the lubricated internals of that turbo, ie bearings.
    308  0
    manual · 1G DSM
    Loading...
  15. 99gst_racer
    9,053
    815
    Joined Apr 5, 2003
    Coloma, Michigan
    Yeah, I'm sure that's what they are implying.
    It's just worded poorly (and probably intentionally). It's specifically says they cover turbocharger bearings, but will NOT cover parts related to a turbocharger. It reads contradictorily regardless of what it really means.
    I'd be interested to hear of someone's experience with putting this "engine guarantee" to work.
    Street Build 6K  67
    Loading...
  16. Black91TSiAWD
    171
    Joined Nov 30, 2004
    Yeah, I did notice the contradiction there and do agree it was probably intended.
    Id love to hear of someone who has had to file a claim, but I think this is a new thing and their is an 18 month starting period you have to get through to be able to make a claim.
    308  0
    manual · 1G DSM
    Loading...
  17. PIMking
    PIMking Proven Member
    1,434
    Joined Jan 29, 2008
    tuscaloosa, Alabama
    My vehicle that I had in iowa had over a half a million... Yes it was my dump truck but with all the dirt and sand and beating that thing took its a feat all on its own.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
