Upgrade to T-28 before exhaust and Fuel upgrade?
sting0004
430
Oct 29, 2002
Buckscounty, Pennsylvania
I can get a forced performance t-28 sport for $365 shipped. It looks like its in good condition. Is the FP t-28 sport as good as any other t-28? Could I install it without a 195 fuel pump while running stock exhaust? I will be getting exhaust and a 195 pump soon, but would it be ok to run with the new turbo for a little bit before the other upgrades? I think I have everything else I need to run the t-28 for now. Thanks alot, Matt
yeah you should be fine...I wouldnt push it yet IMOP, Cause the t-28 is just a much better t25 un less it is the big t-28 killer which has a much bigger compressor housing. Where are you getting the turbo from I want the big t-28 killer for my final turbo.
I'm getting it used. The reason I said its a good deal is becuase it has low miles on it. Any more replies? Thanks alot, Matt
yup...just keep the boost at a reasonable level and you should be fine until you're ready do the rest of your mods...have fun
sounds like a good deal, you can get it and let it sit till you get the rest of parts (which is hard to do youll install it anyway :D )
I run a T28 with the stock fuel system, but I run low boost( 13-14psi)
Originally posted by larryd
Personally I would just buy it and put it aside until you can afford to do your exhaust and fuel work. Atleast the exhaust.
That is what I would do too. I personally would not install a bigger turbo before puttin in at least a FP and exhaust.
  • Wanted 2g Looking for a clean title minimal rust roller
    Looking for a 97-99 eclipse GSX roller, has to be clean title with minimal rust. The closer to...
    • SBjunkiie
  • For sale Jmf race manifold
    6 bolt jmf race manifold throttle flange is for s90 Asking $400 plus shipping
    • spoolinjuice
  • For sale 1g 1G EDM Taillights for sale
    • Shaxzy
  • Wanted 2g Front glass wanted
    Hopefully some has one or has a lead on one but im having a hard tome finding any
    • 2gRhino
  • For sale Dynatek ARC-2
    Dynatek arc-2
    • FWD
