jlust07
- 3
- Aug 25, 2022
Pullman,
Washington
This plug has a green and white wire with a green and yellow wire. It goes through the firewall to the dash connectors. (NOT THE ECU)
Second plug I am not sure about is this 4 pin, it looks like it exits the harness near the Idle speed controller, it has 4 blue wires. Couldn't find a spot to plug it in with my car.
I was also curious if someone could verify this image. I had previously plugged the first plug shown in this post into number 6, which at the time I had assumed to be the temperature sensor. Although following a wiring diagram, the temperature switch goes to a yellow green, and green and black wire. If anyone has information on either of those too plugs this would be greatly appreciated. If anything I want to make sure I'm wiring up the ECU water temp up correctly .
