two Bosch 044 fuel pumps?
talon187
20+ Year Contributor
1,044
Feb 11, 2003
torrington, Connecticut
Ok Ive had three 255 wallbros and they keep dieing so i refuse to buy another one. my buddy is parting out his car and had the same problem with the walbros. He picked up two Bosch pumps. Im not 100% sure what model they are. I thought it was only good for like 350 hp. maybe im wrong. But would there be a big problem running two of them?
if they are 044's they are good for more than 350 horse and using two would make for a lot of fuel, which you may need depending on what fuel you plan to run. overkill for 350hp though
im making over 400 im going for 500-600
You still only need one. Unless you are shooting for 600whp on E85. Maybe a little more info on your goals and mods will help. But I'm guessing you will only need 1 of these pumps, if in fact they ARE 044 pumps.
For 500-600 u only need one if its an 044. The shop i work for, when we do a dual 044 setup we call it our 1000hp fuel system. Dual 044s would be nasty but definitly overkill for the hp ## lookin at.
2 044's ran in parallel with a -8 feed should easily support 1000hp on gas.
I run a intank 300lph supra pump feeding an 044 ran inline along with -8 feed.
Nice how im running it is two -6an lines out of tank to a block that goes to a -8 up to the rail and filter. Now i need to find a place to mount them anyone have a good place under the car of course
So the consensus is that a single 044 is good for around 600 base HP on gas? Or was that wheel HP?
I'm switching to a cell, so I won't be able to use my in-tank Supra pump feeding my 044 anymore. I'm trying to determine if a single 044 will support roughly 600 WHP on 110 octane race gas. I'd really like to not have to buy a second pump unless I have to.
