Jason99GSX
- 2
- Oct 3, 2011
Lehigh valley,
Pennsylvania
Have a QM twin disk in my car. I’m curious if this sounds like I may have the clutch pedal adjusted incorrectly. The engine is brand new. Few passes around the block is all it has on it. But having an issue where I would press the clutch and the car would die or try to die. I thought I was over disengaging the clutch and read that I needed a clutch stop. Added it and still can’t get it to work correctly. Talked to one or two people and was told I shouldn’t need a clutch stop. I’m hoping this is an easy fix by just adjusting the clutch pedal properly. I was able to adjust it to the point with the clutch stop where I could press the clutch in and it would t die but as soon as I would attempt to put the car in gear it dies or I will get locked out and can’t even get it into gear. I’m really hoping this is just something stupid and something isn’t seriously wrong. Can anyone help me out ? This is the only thing holding me up from breaking in my fresh build and getting tuning done etc. Thanks in advance.
