TURBO XS Standard Boost Controller
Gallina
37
Feb 21, 2004
new brunswick, New Jersey
Is anyone using the Turbo XS standard boost controller ? I can get one for 50 brand new. I was just wondering it this is a reputable boost controller. I hear horror storys of boost controllers malfunctoining. thanks
nick
I use this boost controller. There is nothing wrong with it. You can get a cheaper MBC from elsewhere, or one that doesn't require an allen wrench to adjust. It is up to you.
-T
The turboxs mbc is really a relible boost controller its when you get into electronics bc is when you have 2 worry. Another reason people have boost creep is if you do not use zip ties on the ends of each vacuum line that connects to the bc make sure its a good tie seal..Or you will have creep.
thanks guys. Ive acutly decided to get the Joe P MBC . I hear really good things about it. Plus it was cheap and also if i want in the future i can make it a EMBC for 200 bucks . anyone on here use joe P mbc or embc ?
The boost controller hold boost very well. Its very reliable and easy as hell to install. got mine from extremepsi.com
