Turbo= Whistling more and Car is jerking
98SilverGS-T
351
Jun 27, 2002
pomona, California
I just recently put in my MBC and NGK BPR7ES plugs and set my boost to 15 lbs. When I go WOT my turbo sounds like it's whistling a lot more (almost like its working too hard) and when i let off in gear my car will jerk (almost like running a stock BOV VENTED). I'm also starting to smell something like exhaust fumes when i go WOT also. The plugs are gapped @ .27...my question is : I was planning on getting a fuel pump this week to hopefully make things better ( i was told to get one a.s.a.p by someone @ RRE) but I need to know why my car is doing what it's doing first. I don't want to add things when I have other problems to deal with first....Any help would be appreciated
Anthony
well, the plugs are supposed to be gapped at .028. i would gap them to that, then if it doesn't help check your plug wires, if they are pretty hold you should go ahead and change them anyways.
Hmmm...I really need to know what's causing the jerking and whistle. I don't want one problem to lead to another you know :-\ . I'm assuming the fuel pump is a wise choice for my next mod then.....?
I think it sounds like a boost leak, if your turbo sounds like it is spinning really fast that is most likely what it is.
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
