Turbo Sizing Guide!
Benji
117
Mar 14, 2003
Mitsubishi:
16g = 34lb/min
Big 16g = 36lb/min
20g = 44lb/min
Forced Performance:
Big28 = 36lb/min
AGP:
L1 = 41lb/min (400BHP) T04B comp housing
L1R = 42lb/min (no data available)
L2 = 49lb/min 50 trim (520BHP) choice T04B / T04E
L2R = 54lb/min (550BHP) choice T04B / T04E
L3 = 60lb/min 60-1 (610BHP) T04E comp housing
L3R = 62(65)lb/min (630BHP) T04E comp housing
Extreme Turbo:
ETA12 = 36lb/min S-trim (360WHP) ETA comp housing
ETA32 = 48lb/min 50 trim (440WHP) ETA comp housing
ETE32 = 48lb/min 50 trim (460WHP) T04E comp housing
ETE42 = 50lb/min 60 trim (500WHP) TO4E comp housing
ETE52 = 55lb/min 60-1 (550WHP) TO4E comp housing
GT30 (ball bearing) turbos:
48 trim = 44lbs/min
52 trim = 50lbs/min
56 trim = 55lbs/min
60 trim = 60lbs/min
gt35 trim = 65lbs/min
Garrett:
T-28 = 34lb/min (350BHP)
50 trim = 47lb/min (GREEN)
57 trim = 49lb/min 60-1 = 65lb/min (RED)
The following is from Turbonetics Catalog:
On TO4E Compressor housings:
50-trim = 47lbs/min
54-trim = 45lbs/min
57-trim = 49lbs/min
60-trim = 50lbs/min
T-100 = 180lbs/min
TO4B compressor housing:
60-1 = 65lbs/min
62-1 = 70lbs/min
:thumb:
who upgrades (or downgrades) to stock?
if a s16g is rated at close to 505cfm, and that equals close to 34/lbs a min. and the big28/big16g are 550cfm, 36/lbs a min......i think you can figure out the rest.
That's very thoruough.
Some vendors offer a TS04 housing with there turbos. A very big housing but still worth including.
thats not true. Unless I missunderstood the formula, you just take lbs per minute and devide that by .075 to get the cfm the turbo flows. If you take a big 16g with a flow rate of 36lbs/min, the formula only gives you 480 cfm, when the actual cfm is 550.
please correct me if I'm wrong.
One is mass, the other is volume, so there are variables that come into play. 550 CFM won't ALWAYS be 36 lbs/min, because there are other factors such as temperature, pressure, etc. Read through the link I posted earlier-- some people a lot smarter than me put some good info in there.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
