1G Turbo modification question.
Stone5000
Dec 28, 2014
Nicholasville, Kentucky
What are the pros and cons of running a forward facing turbo rather than the original setup?? (92 Gsx Auto)
The only pro is slightly widening compressor map efficiency from the small increase of atmospheric pressure at the inlet at higher speeds. Strictly Drag racing only.
As for cons, there are plenty from a comfortable street car perspective.
-Ingesting debris, as most do not allow a filter to be fitted.
-Use of half size radiator, which depending on which part of the country will limit your street duty time.
-Clearance issues, Powersteering might have to be removed and alternator relocated.
-Removal of AC components.
Okay thanks a lot man I appreciate it . Still pondering on what to do with this Auto car I just picked up.
