turbo install question
TurboPseidon
Dec 16, 2002
Chatham,
I just got in my new precision SCM-61 and it came with a braded line...should I run this turbo off the head like the stock turbo OR run it off the filter housing BUT i heard there is maybe to much preasure there.... and this turbo is only Oil cooled so how do I block off the coolant lines like the banjo? thanxs...
RRE has a pic on which plug you remove for the ol supply line. My 50 trim is also oil cooled. i plugged the water lines with bolts and clamps. The plug you remove from the oil filter housing will plug the water pipe where you remove thesteel water line that goes to the front o your old turbo i believe. I would contact your vendor so you cover yourself. Mark
