mike11743
- 0
- Oct 17, 2011
Pittsburgh,
Pennsylvania
Hey guys, i recently turboed my 98 eclipse 420a. Everything is good except my 38 mm wastegate does not work on my log manifold. Basically the plunger that plugs the manifold hole is too big for the hole. It is tapered on the edges, but has a slot in the middle, but not where tapered. This slot is letting boost right out because the tapered part is not sealing the hole but rather the plunger is sitting flat causing boost to leak out the slot. Basically im wondering if its possible to buy just a plunger or a whole new wastegate. I have a cheap XS Power wastegate
I am also wondering the 38mm would be the plunger size correct? Would say a 35mm still bolt up to my manifold even though the 38 bolted right up, also would i still be able to use my dump tube. I had to do a lot of work to get it to fit right.
