Turbine Housing for FP Red with Internal Wastegate
Planckscale
109
2
Oct 16, 2007
Tanzania, Africa
Hello,
I purchased FP Red a while a go but never used it. It turned out that it is setup for External Waste gate since the WG flapper is removed. My question is, where can I find a turbine housing with the flapper intact? Can I just buy a TD06 8cm? I need a cheaper solution and prefers internally gated over external WG...
Thanks
Thanks for your input. Would you then suggest that I should just buy an 02 housing with with External Wastegate?
Highly....you'll never properly-control a turbo with a 60+ lb/min compressor wheel through an internal gate. They're slow to open, slow to close, and don't like to stay closed at high pressure...not to mention the angle required for fitment isn't a straight pull, so it wears the flapper bushing extremely fast.
