Dstarperformance01
- 880
- 172
- Mar 5, 2016
Mustang,
Oklahoma
Looking for someone that does remote tunes for AEM EMS V1 or close to Oklahoma. Thank you for any inputs or suggestions is greatly appreciated.
It’s no older than link technologyThat might be tough as it's such an old ecu. Try Jeff Evans of Evans Performance Academy, Kevin Jewer or Kenny Kline. I've worked with all 3 and would recommend them all.
Drive it WOT all the time then..............
JK, give her all the love that Lucy would have got!
The start up,cruise, at a stop and idle afrs are all over the place( mainly lean). I think it’s a possibility that it’s shit ethanol. So I’m waiting on a couple of parts to come in to fix some slight oil leaks as the car has sat for a while and things have dried out. I need to download the software for AEM so I can send you logs but at this time I have nothing else to offer as I’ve only driven it about three/four times. I appreciate any and all help.What is it in your cruise tuning that you want looked at? Post a copy of your calibration file & a log (log to PC) with you cruising around that covers all the cruising conditions & I'll take a look at it. Make sure you're logging rpm, load, AFR, throttle position, ignition. Also how doess your car do on startup? How does it do with idle & coming to a stop? This will get us able to know what more to ask.
Yeah it puts your video onto the DSMtuners YouTube channel, which is kind of nice because you don't even have to have your own channel that way. So your 2 videos, you can see the thumbnails for them on the DSMtuners "Videos" page here, with all the other videos that are on the channel:I have a video of what’s going on but when I load it, it gives a YouTube link
Not sure what that’s about
You sir were damn near spot on.I've seen this before on a few cars i've tuned but i can't say for certain without a log. I've had a bad tps cause similar issues but it's hard to see what's going on without more solid data
Uh yeah, definitelyThat will definitely help.
