splashofgsx
- 0
- Jul 21, 2011
schererville,
Indiana
hey guys hows it going,first off i want to say sorry if there is already a thread about this, im new to the site but am in dier need of help.
i have a question about my automatic 1997 eclipse gsx. it has an ingen front mount cooler and an exhaust system. also it has a 16g turbo running at 7psi (a little larger than the stock) everything else on the car is stock
so i just bought it the other day and it has a problem dieing whenever it comes to a stop really fast. if you are easy on it when slowing down, sometimes it dosnt die.
also it has a over drive button that i dont know ANYTHING about, when the over drive is OFF, the car idles pretty high like even if you take your foot off the gas. when the over drive button is ON, the car will idle normaly (when you take your foot off the gas going like 20mph, it will go back to idle rpms around 1000)
the only things i could think of could be
-maybe i need a better fuel pressure regulator
-air control valve
-idle air control valve (i dont know if these are the same)
-and maybe the MAP sensor?
ANY help would be GREATLY APPRECIATED i reallly dont like my car dieing on me
-air control valve
definitely not fuel cut
Not trying to beat a dead horse but i didnt see you say anything about recirculating your bov that should be very high on your list seeing as most likely that is your issue
